[SOLVED] Creating a D-Former from script
Mike3DMike3D Posts: 95
I'm trying to create a D-Former from script.
I can either trigger the 'DzNewDFormerAction' action, or create a DzDForm object.
As I want a 'silent' creation (no user interaction), I can't use first solution (action trigger).
When trying to create a DzDForm object from script, the other components (base, modifier & zone) are also created, but the setup seems incomplete :
- the modifer ('D-Former') is not selectable (not highlighted) in the Scene pane and can't be deleted
- no colored vertices are shown in the viewport, even after setting zone influence to 'Sphere'
Maybe a complementary action is required to complete the setup ?
Code to reproduce the issue (with a figure or primitive selected in the Scene pane) :
(function(tgt){
// Create new D-Former
var dForm = new DzDForm();
dForm.setName('D-Former');
dForm.applyToNode(tgt);
// Get modifier
var modifier = dForm.getModifier(0); // DzDFormModifier
print(modifier);
var zone = dForm.getZone(); // DzDFormZone ('Field' in Scene pane)
zone.setInfluenceMode(DzDFormZone.Sphere);
dForm.deleteLater();
modifier.deleteLater();
zone.deleteLater();
})(Scene.getPrimarySelection());
Post edited by Mike3D on
  • umblefuglyumblefugly Posts: 245
    edited August 17
    I think the issue is that new DzDForm() creates the D-Former object, but it does not perform all of the setup that the normal New D-Former action does.
    applyToNode() creates/applies the modifier to the target, but the D-Former itself still needs to be added to the scene:
    Scene.addNode(dForm);
    Without that, the associated objects exist, but the Scene pane and viewport do not fully treat the D-Former as an active scene object.
    The colored vertex display is also separate and can be enabled with:
    dForm.setDisplayWeights(true);
    Also, these lines should be removed:
    dForm.deleteLater();modifier.deleteLater();zone.deleteLater();
    because they schedule the objects that were just created for deletion.
    So in short, DzNewDFormerAction appears to do some additional scene/display setup beyond simply constructing a DzDForm and calling applyToNode(). When creating one silently from script, those extra steps need to be done manually.
    Post edited by umblefugly on
    If you still can't get it to work, i'll share a possible solution.
  • Mike3DMike3D Posts: 95
    edited August 17
    Awesome ! It works perfectly smileyyes
    (function(tgt){
    dForm.applyToNode(tgt); // This also creates a new DzDFormModifier
    // Get modifier & set weights
    modifier.setInfluenceWeights(new DzWeightMap());
    edited August 17
    Ugh pasting code here is a nightmare.
    But you are close:
    dForm.setName("D-Former");
    dForm.setLabel("D-Former");
    Everything works perfectly now smiley
    Infinite thanks for the helping hand yes
    No problemo :D
