TOON RENDER?
We used to have the option to do a toon render in the render preview.
How can I toon render my scene/model without have to just apply the shader manually?  Can we even do this anymore?
  • Richard HaseltineRichard Haseltine Posts: 112,229
    Enable Show Hidden Parameters in the Render Settings pane option menu - the lined button in the top corner, or right-click the tab. Do bear in mind that the setting affects only surfaces using the Default DAZ Shader.
  • visiblemanvisibleman Posts: 178
    OK I'll try that.
    Thanks!
  • RuphussRuphuss Posts: 2,631
    asking again why is this hidden ?
    Because it was hardly ever used and caused more problems by being accidently clisked on when not hidden?
    I suspect it may be ebcause so few items, particularly human characters, come with the Default Daz Shader applied - most use the HSS, uberSurface, or the Age of Armor SSS shader - and so won't render in toon mode.
