RSSY 3Delight to Iray Converter problems
I've had the RSSY 3DELIGHT TO IRAY Converter for a few years now, and recently, it has stopped working. While I can scan fr 3Delignt materials, when I hit look for matches, nothing at all comes up anymore, making it impossible for me to use the converter. Help.
  • Richard HaseltineRichard Haseltine Posts: 111,949
    There is probably a PA thread on this, possibly with a link from the isntalled files. It would be better to post there so the PA is likely to see it.
  • memcneil70memcneil70 Posts: 6,173
    I didn't see a post in the Commercial Thread so I thought I would note my recent experience for you. I was updating some old .daz and .ds materials to .duf extensions for 4.24.0.4 and 6.25. I first converted the files from .daz to .duf then updated the materals to .duf using Code66's Legacy Set Converter and Advance Material Converter - which allows you to access the RSSY 3Delight to Iray Converter shaders within its program, as well as other shader sets. You may have to do the same if you want to convert with the RSSY 3Delight to Iray Converter fully.
