4.2 .64 Issue
Each time I open DAZ Studio 4.2.64 the screen goes on forever showing preparing screen when nothing is in screen! Is this normal or do Ihave a problem? Cheers
387 x 206 - 66K
  • Richard HaseltineRichard Haseltine Posts: 112,072
    That isn't a version number (versions are four numbers separated by dots. 4.2 would be a beta, 4.5.x.x was the first general release and we are now up to 4.24.0.4 for DS 4 (major version four, minor version 24, build 4). Is DS meant to be loading a scene, or is it meant to be opening to a blank sene?
  • Thank you for your reply. It is opening with a blank screen. DAZ Studio is 4.24.04. I just re downloaded and installed again in case it solved the problem! It did not! Just for reference this computer is also running DAZ Studio 6 and has an NVIDIA 5060 ti graphics card! Cheers
  • PS. On my other computer which has a 16 gig NVIDIA 4060 ti graphics card there is not any problem! Just wondering if the 5000 series card might be the problem! Cheers
  • jmucchiellojmucchiello Posts: 2,747
    Daz 4.x cannot, does not, and will not use a 50xx series NVIDIA card. Ever.
  • PadonePadone Posts: 4,377
    I was conviced that was limited to rendering. It appears 50xx can't even handle the viewport in DS4 ? If so you can try to plug the monitor to the mobo instead, that should use the integrated graphics for the viewport.
  • LeanaLeana Posts: 13,667
    It is limited to Iray rendering. Viewport and dForce should be fine.
    Yes, I have a 50x0 card and can run DS 4 (and do CPU renders using Iray, just not GPU)
