render progress window
using v, 4,24  (waiting for my scripts to be updated before moving to 6). everything worked fine until this morning when DIM reinstalled 4.24. I did it accidentally when I installed new content. Since then, my renders work but they don't show in the progess window until they are 100%. I often start a render and stop it to make adjustments. How do I get back to showing the render in progess
  • tophandtophand Posts: 141
    to claiify, I'm talking about the window that displays the render as it develops. Not the progress bar
  • barbultbarbult Posts: 27,675
    edited June 21
    There are to options for Render Destination. One is New Window, which should show the image while you render it. The other option is Direct To File, which will not show it while you render. Check your setting in the Render Settings pane. See the attached screenshot.
    623 x 525 - 64K
    Post edited by barbult on
    Thank you! I found a video on setting my graphics settings especially for Daz  and that cleared up the issue
