Error loading Genesis 9 figures
ZoritaeZoritae Posts: 58
Hello.
Both Daz 4.24 and version 6 are not loading the figures correctly.
For example, all the female figures load with exaggerated hips, and the male figures with feminine torsos.
Could I have some incorrect settings?
Regards.
  • LeanaLeana Posts: 13,629
    You likely have installed a character with a morph mistakenly saved with a non-zero default value, so it is applied automatically to all G9 figures.
    In order to identify that morph, you can try this:
    • load the base G9 in an empty scene, and select it
    • zero the figure, and confirm that you actually want to zero it (ie set all values to zero) and not restore it (set all values back to to default)
    • check the "currently used" section in the parameters tab: you should see all parameters which have a value different from default there. As the faulty morph has a non-zero value but is currently set to 0 it should appear there.
    Once you know which morph it is, check if there's an update for the character, it might have been fixed. If not it's possible to edit the morph settings yourself to fix the default value.
  • Richard HaseltineRichard Haseltine Posts: 111,921
    Moved to Technical Help as it is a content issue, not a Daz Studio application issue.
