{Diffeomorphic} Rigid Follow Nodes
evilded777
Greetings,
new to all this Blender stuff, but trying really hard to understand it all. Diffeomorphic seems a brilliant tool. My G8M character has earrings attached by Rigid Follow Nodes, after import they end up as part of the figure mesh rather than as seperate items and they are out of place. Finally figured out how to move them, but getting them into the right position is beyond my Blender skills just yet.
Should I remove the Rigid Follow Nodes and just parent the items in DS first?
Thanks
This is probably a regression, now reported to Thomas. For the time being be sure "apply transforms" is disabled in easy import, this way everything should work fine.
https://github.com/Diffeomorphic/import_daz/issues/39
p.s. If you didn't, be sure to update to the dev version as bugs are only fixed there.
Thanks for this. I wish I knew my way around github better than I do, but I totally don't understand how to get the "dev" version.
I don't mean to pile on here, but... again... new to this, so I am trying all kinds of different things to learn how it all works. I've got a character that is G8.1M, using the G8M UV because that's the freckled skin I need... also using a 3rd party geograft. When I import him, the Body and Head materials think they are part of the geocraft's shell rather than being part of the figure so the materials are all wrong. Clearly I can't post a screenshot since he's got those dangly bits. I wonder if I am doing something wrong? Or does this combo just not work because its on the wonky side?
Nevermind this, I figured it out. The proper elements were not turned off on the shell.
Yes there's a limitation for shells where blender can only import the surfaces visibility. Of course tools are provided to fix this in blender, or you can fix the shell in daz studio before exporting, to only use the surfaces visibility.
https://github.com/Diffeomorphic/import_daz/wiki/Shell_Editor
https://diffeomorphic.blogspot.com/2020/11/multiple-geoshells.html
p.s. The dev version is the master on github, you can also follow commits and issues there, or participate if you find any bug. Answers and fixes are usually fast enough.
Scaled characters and things like ear rings.
I just can't seem to get the ear rings right. The ones I used to use, with the rigid follow nodes, prompt errors about invalid meshes so I ditched those and actually found ones that I like better. These do not use rigid follow nodes, but they are very often not parented in the right place. Does this have anything to with the fact that I have a shorter character? He's scaled down to about 89%.
Invalid meshes are fixed by blender on import, there shouldn't be any problem with rigid followers and hierarchies. But invalid meshes may have problems with morphs as blender may need to delete some vertices or change the vertex order to fix the mesh. Again you need to get the 5.2 dev version as some issues with rigid followers and hierarchies are fixed there lately.
p.s. And in general always get the dev version before reporting bugs.
