Reinstalling Daz
I have the previous version of Daz Studio, but because of my humongous library, the loading process took FOREVER. So I'm getting a separate C drive just for Windows, which I do NOT want to put Daz Studio on. How do I install DS to one of my basically empty drives? Thanks!
AK
  • Richard HaseltineRichard Haseltine Posts: 111,137
    Set the software base path in the Advanced settings in DIM, if you mean the application and plug-ins. Or are you meaning content?
  • alan bard newcomeralan bard newcomer Posts: 2,424
    not exactly what I was going to ask but close enough.
    the first couple installs of the alpha I did worked and then they would not show the base window.
    by base window I mean the one with the file edit commands along the top
    did a single screen layout and still that screen would only show up when you use ctrl-Q and then as a two inch wide quarter inch high saying are you sure you want to quit.
    both 4s work fine.
    So before I install the new 6
    what should I pull out of roaming so the new installer has nothing to retain and does a totally fresh install?
    Obviously all the old alpha folders from the program files and anything relating to them from the roaming data.
    Is there something in the daz libary folder to clean out?
    So basically return the system to what it was before any alphas were installed.
    Just updated the public build beta it opens, shows the scene window and content lib where they should be.
    but not the main window.
    opened 424 reset it to a single monitor layout saved and closed
    Will now see if that resets the betas to the same layout (I did before and it didn't work)/.
    Okay, neither 6alpha or 6 a public have any user layouts in roaming other then default startup
    And makes no difference.
    Using F3 to open setting there is a reset to default but it take great glee in telling me that it will default to the original version of the last selected layout which. The one that doesn't work
    At this point it would seem I have to purge all d6 alpha beta etc folders . . . anywhere else to look beside roaming and program foldlers?
    image 1 all I get with alphas, scenery pane, content dragged from second monitor to show in picture
    image 2 424 same layout but with main window
    image 3 reset layout to single monitor works in 424 but alpha not acknowledging new settings
    is there an ini file anywhere?
    Obviously if I can't get the window that allows me to change the layout, I can't change it
    is it hardcoded once the layout is chosen?
    1519 x 1710 - 319K
    3115 x 1710 - 445K
    3675 x 1710 - 608K
    The general release and the beta (Public Build) are separate, they do not share settings.
    AK
    it's always best to put the programs on the C drive. (although once you install daz you can copy the installed folder off to another drive and it will run just fine which is a good plan to copy you current working daz prog folder before doing an update so you can still run in the new install has issues.
    But install all the data on a separate drive or two.
    You can use dim to install some items like scripts etc to the library on the C drive but send everything else to other drives.
    I have C drive solid state and E drive and G drive with the data files and another drive that gets the installers downloaded to it.
  • DamselDamsel Posts: 406
    I mean all of it. I want to put Daz on its own drive.
    alan bard newcomer said:
    Thanks!
    AK
  • butterflyfishbutterflyfish Posts: 1,749
    DS doesn't need to be on your C Drive. I have it installed on my E drive with no problems. I have some of my libraries on my E drive and some on my D drive. DS doesn't care where you install it, as long as you tell it where your libraries are.
    Okay, 6 installed and put the main window back in.
    when the alpha were installed they took the content directories from 4.
    how do I make 6 copy the content directories
    I have daz stuff over 3 drives and some of the stuff is duplicated over a couple drives as backup.
    I'm guessing that somewhere there's a file I can copy from the win4 to the new win6 so it will know where the directories are?
    If so, what and where is it?
    And no, I don't want it to search 16 tb of folders to gather content.
    Do I have to reintalls all plugins also?
    In my case the C drive is an M2 solid state.
    My data drives are 4 tb regular hard drives.
    Once the program loads on the C drive and loads the data it should run much faster particularly if you have a solid state C drive and also the system is on the C drive so the command lines from the cpu to the program and video cards should be quicker.
