• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
    • Game Ready
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
  • Download Studio
  • Menu
  • Daz 3D
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
Notifications
Loading...
    • Categories
    • Recent Discussions
[diffeomorphic] some hairs look like plastic in cycles
bigoskar00bigoskar00 Posts: 36
May 22 edited May 22 in Blender Discussion
so I have this issue with diffeomorphic where some of the hairs that I export looks like they are made from plastic. This only happens with some hairs, while some look perfectly fine off the box and others look fine in eevee for some reason some look weird in cycles and only in cycles
here are some examples:
the hair is https://www.daz3d.com/alyssa-ponytail-hair-for-genesis-8-females?srsltid=AfmBOorllVCJVUcgEAn377Nk6OHSMRtskKLNoroaZkQIysz0kr4z5sS5
before someone asks I know about light paths and how some hairs need the light paths to be cranked up, this are the numbers that I used for this preview
and as a comparison here is the exact same hair with nothing changed in eevee
as you see it looks more natural like actual hair
this happens with a few of the hairs that I use but not with all of them, some look perfectly fine in cycles right out of the box with no issues, here are some examples
https://www.daz3d.com/hs-smooth-bob-hair-for-genesis-9-8-and-81-females?srsltid=AfmBOoqBxoX8wrPR8r16_skLlON1-EzRI6d63WaFbMamleXyiVEUPfId
https://www.daz3d.com/catrina-hair-for-genesis-9?srsltid=AfmBOoo4JKaFtE7dMbGkYQKngYKRKFJeXp_LXuSAqd0SV-ehxGtD7q3A
https://www.daz3d.com/fe-refined-short-hair-for-genesis-8-and-genesis-9?srsltid=AfmBOorUr7ASQ0wLtNuFOynAQ7EZpkX_Jr2N3yAdbKYSRelIWOUSAgo6
those three hairs looks fine in cycles and eevee, I have no issues with those
Post edited by bigoskar00 on May 22
  • PadonePadone Posts: 4,335
    May 25
    What is your light source ? It seems there's strong lights from all sides, while reflections need a main light on a relatively dim environment to show off better. Did you try the same light in daz studio what you get.
  • hardwire666hardwire666 Posts: 79
    May 25
    Make sure it's using the normal map. I imported the asset myself and the Normal map makes a massive difference Diffeo doesnt import the normal map in either FBX compatable, or Extended for that asset.
    May 26
    Yes, I can confirm. Alyssa is using the BDL hair shader, which is intended for strands, while Alyssa is geometry ribbons not strands. The BDL shader is approximated in blender, so it doesn't generally look the same as iray, especially if we use the principled option as eevee can't render any hair shader in blender, so it is converted to principled. With the BSDF option the conversion is better, as it is converted to a hair shader in blender, which only works with cycles.
    The bump map is not imported as it doesn't make sense for hair shaders in blender.
    However, there's an option in the global settings for hair materials. The "smart" option will ignore the BDL shader if the hair is not strands, and use a uber conversion instead. This way the hair is converted as if it was a uber shader, and the bump map is imported. Still it will be different than iray.
    Another option with this kind of hairs, is to convert to uber in daz studio before exporting, just applying the uber shader. As again BDL is intended for strands. In this case the conversion will be the same as iray.
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
