How to remove breasts?
OrbbOrbb Posts: 11
Hi,
I bought this character for a project : https://www.daz3d.com/mb-ritta-hd-for-genesis-9-bundle
...but the anatomical proportions are inappropriate for a child model. Is there a specific morph or setting included to flatten the chest area and make the model look like an actual child? If not, how can I remove them?
Thank you!
Post edited by Orbb on
  • garrett_3dgarrett_3d Posts: 907
    Looks OK to me. At a guess I'd say she's meant to be 13-14 years old.
  • Richard HaseltineRichard Haseltine Posts: 111,467
    Does she actually looik like the promo? How does the base Genesis 9 load? If the issue is more obvious breasts than in the promos it is likely that another shape is saved with a non-zero default and so is getting applied to every figure you load.
  • jmucchiellojmucchiello Posts: 2,155
    There are varioius assets that provide ways to control this. I own both of these and I've gotten mixed results with both of them. Just don't combine them. :)
    https://www.daz3d.com/breast-utilities-for-genesis-9
    https://www.daz3d.com/gvp-chest-smoothing-morphs-for-genesis-9--volume-2
  • GrapeGrandpaGrapeGrandpa Posts: 40
    If you go to the chest sliders on the shaping tab there should be a "breasts gone" morph.
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,577
    edited May 12
    if you export the character as an obj at base resolution, you could reimport it in morphloader apending it by only the pectoral section and create a morph slider for that
    or use the Dformer tool in DAZ studio
    or send to Hexagon and use the smoothing tool
    also https://www.daz3d.com/shape-splitter
    the Premier member build also has the advanced Mesh Grabber but you can buy the original bundle still
    https://www.daz3d.com/mesh-grabber-bundle-win
    too much to explain how to do each of these but all basically the same thing, reshape the mesh and create morphs
    I myself use Zbrush and morphloader/obj import/apend (for the morph creation)which is probably the most expensive option but since I own it, having bought it a decade ago, I never really bother much with alternatives
