Trying to replicate a skin colour
Hey guys,
I'm rather new to DAZ Studio and I'm trying to replicate a certain stimulus for my bachelor's thesis.
Someone has created body stimuli using the genesis 8.1 basic male model (see attached) and I want to recreate these male models + create matching female models. The person has outlined their parameters in a document (see attached), however when I use those parameters my characters look way darker. Could this be due to the person using Daz Studio 4.22 and me using Daz Studio 4.24?
Thank you guys so much in advance!
481 x 891 - 137K
606 x 446 - 53K
481 x 891 - 313K
  • Richard HaseltineRichard Haseltine Posts: 112,078
    Are you using the same lighting? A saved scene should be sharable if you want to make sure.
  • StratDragonStratDragon Posts: 3,291
    Lighting from the first image is coming indirectly from the front, light from the second image is coming indirectly from the left. move your light, or if you are using an HDRI light, move the dome using the rotate parameters, then adjust the exposure. Lighting is its own science in photography and 3D. A strong advantage with Iray is the science behind how lighting works with or against photography is exactly the same as photography. A good photography tutorial can help you get much better results in lighting a 3D image.
    sickleyield is a 3D artists who contributes to these forums and writes tutorials. A google search will provide a treasure trove of information, but good lighting in a scene is not possible without trial and error.
  • FishtalesFishtales Posts: 6,244
    edited May 3
    He is using skin tone values for the skin colour but he may have different settings than you in the other parameters. The chart I have added in the attachment might help with skin tones.
    pdf
    pdf
    Photoshop Elements _ Color Correction _ Skin Tones _ Skin Tone Samples Chart.pdf
    72K
    Post edited by Fishtales on
