Modifying Morphs Troubleshooting
I recently obtained Lycan 9. I was interested in having a shape morph from it that only affected the legs, but by default Lycan 9 is all or nothing with its body morphs. I tried to follow the advice provided by Esemwy in 2018 here. I have followed his instructions to a T, but when I go to apply the morphs with morph loader pro, it won't load.
I'm fairly amateur using Daz3D. My assumption is that I'm missing something that has changed between now and 2018 when Esemwy made his guide. Thank you in advance.
  • Richard HaseltineRichard Haseltine Posts: 112,197
    A couple of obvious things are that the export was not at base resolution and that the export included attachments (eyes, teeth, etc.). In any event this won't necessarily work well as you may well find an abrupt jump in the transition from morphed to unmorphed areas, and are likely to need to add various joint adjustments. You won't be able to split any HD morphs, either, just the base resolutuon.
  • iwuvhugziwuvhugz Posts: 0
    Are there any workarounds you would recommend?
