ZBrush Export Question [SOLVED]
MrRogerSmithMrRogerSmith Posts: 175
If I want to export a single item to ZBrush, I can simply click "Send to ZBrush" and it opens in ZBrush, no problem.  But I want to export a pillow and make deformations based on the character's head which is sleeping on the pillow.  And I don't know how to export the character in addition to the pillow.  Parenting the pillow to the character doesn't work as only the character gets exported.  Trying to export both separately just replaces the thing that got exported first.
Any tips?
Post edited by MrRogerSmith on
  • crosswindcrosswind Posts: 10,351
    You can just Ctrl + Select the items that you want to GoZ in Scene pane, then Send to ZBrush. You should be able to find both the figure and the pillow under Subtool.
  • MrRogerSmithMrRogerSmith Posts: 175
    Thanks Crosswind.  I was going to respond to you that I'd tried that already and it only sent over the character, but I just tried it again and it actually does work so I guess last night's failure was user error.
