unable to active plugins
MarcosGABMarcosGAB Posts: 25
Hello, i'm having a problem, i'm unable to active some publisher plugins (Autosave, Shaping Transfer and pose converter) i tried it in daz24 and 26 doesnt works, it says that must to be registredm to active, can some one help me?
Post edited by MarcosGAB on
  • LeanaLeana Posts: 13,521
    Those are premier plugins.
    You need to log into your account from Daz Studio: if you're a premier member it will then activate the premier plugins. You don't need to stay logged in to use the plugins but you'll have to do it once in a while so DS can check that you're still a premier member.
    But i'm always loggedin
  • As a PA you should see https://www.daz3d.com/forums/discussion/comment/8947571/#Comment_8947571 and open a PA support ticket if that doesn't work.
