Remove JCM
Hello, sorry if this has been asked before but when I search the forums it just takes me to the daz store.
back when g9 first came out I had a go at making my own arm morph and creating a jcm for it. I now no longer want or need that morph but every time I load any g9, including the base g9 it gets applied. I've tried removing it from the property hierarchy in both the bones and parameters but it reappears every time I load any g9. Do I need to save the base g9 again (how would I do that?) or do I need to refreeze the ERC for the morphs? I also tried just deleting the morph but obviously daz still looks for it when I load in a g9.
thanks
  • crosswindcrosswind Posts: 10,361
    You just need to: File > Save As > Support Asset > Save Modified Assets... then select the JCM (cbs) property with which you removed the related ERC links in Property Hierarchy... or directly delete the *.DSF file(s) of JCM (cbs) from data folder. You can locate DSF file via Parameter Settings.
  • globallyglobally Posts: 133
    Thanks, I'll try that when I get a chance later. Do I need to remove from the bones group or the parameters group in the property hierarchy panel as it seems to appear in both?
    if I just delete from my data folder without unlinking them in the property hierarchy won't daz have a fit if it can't find them?
    No ~~ All the ERC links are set and saved on the JCM property per se rather than its Controllers.... so you can just delete its DSF file. There'll be no issue in terms of what concerns you ~~
    Just tried the easy option of deleting the dsf files but i do get a warning when i load my characters that the files are missing. Do i just need to resave the character now the files are deleted or am i missing something?
    If you have ever saved the jcm propertiy with its value within the character preset or sth. similar, you'll see the message of missing DSF when loading the preset files, just accept and resave the preset.
