DSF Files Missing
Both today's Magic Brush Cabins have .dsf files missing from the DIM install.
Forest cabin = Fireplace & both Bookshelves
Christmas Cabin = Gift
Files appear to be in manual downloads, but simply copying them across doesn't seem to work.
I uninstalled and downloaded again, but the same fales were missing. Is there another way without a full manual install?
  • Are the files in the zip you manually download in the correct place? I would expect the two packages to be identical, suggesting that file name or path are at least slightly off.
  • valkanvalkan Posts: 46
    Missing File message has some some non alpha-numeric characters ahead of the dsf file name. Rest of the file path seems OK.
  • NorthOf45NorthOf45 Posts: 5,921
    I have the Christmas Cabin, and can confirm that the Gift .dsf file is named "???.008.dsf". The corresponding .duf file has the ID as "立方体.008. Translators say it simply means "cube", which is the usual base shape of a gift box.
  • OK, thank you. It sounds as if it is a pathing issue - please report via a Tech Support ticket.
