No open wide pose for Genisis 8 Female?
Is Daz moving everything now to Genisis 9?
  • 8 or 8.1? Did you check for controls for the jaw, rather than mouth?
  • felisfelis Posts: 6,502
    If you in the scene tab expand then head there should be a 'lower jaw' that can be opened in parameters tab.
    There should also be a controller for it.
  • crosswindcrosswind Posts: 10,249
    edited December 2025
    If you use G8.1F, Mouth Open Wide pose control property for G8F is blocked by dummy modifiers. How to make it work, you can check this post: https://www.daz3d.com/forums/discussion/comment/8492761/#Comment_8492761
    Post edited by crosswind on
  • In all honesty, you'll probably need to move the lips (Corners, upper & lower segments) to make a realistic open mouth as well as the expression movements. The standard expressions do look a bit.. odd, shall we say, unless used at very small percentage movements. Getting them right will either take a fair bit of practice or a fair bit of skill or both. I wish you the best with it.
    Regards,
    Richard
