Turboloader selection problem
alofaroalofaro Posts: 43
Hi,
   I have a strange problem with Turboloader, I wonder if anybody has had the same problem, and how they solved it (Daz 4.24, Windows 11). Premise, I have thousands of assets from all sources, that is why turbo loader is very useful for me.
  If I load the turbo loader for a figure (ex. G8F), and then use the "check all" or "uncheck all" buttons, they work fine. If I try to select (highlight) a bunch of morphs and then use the right click to check or uncheck them, I get no reaction to the right click.
 If I try to filter the list, the fliter works OK. But if I try to select some items and then use the right mouse click to toggle (checkmark), there is no reaction.
If I try to apply a filter, the filter works, but if I then click on the "check all" (or even the "uncheck all") button, supposed to affect all the visible moprhs, no effect.
This basically means I have to go and click (checkmark) the products one by one.
I had already the problem in the past, then once it worked, but now I tried again, and again the problem is there. I even reinstalled DAZ, no change, and reinstalled Turbo Loader, no change. It is not a Windows problem, the mouse works fine in all the applicaitons, even in DAZ I can use the right mouse button to get to menus while doing e.g. geometry editing, and there is no problem.
Also, I noticed when I am nin  . Notice I am using the mouse as left-handed (but I tried to change it to right handed, with no difference), and I have both a normal mouse and a 3d Connexion 3d mouse connected (but as far as I recall, the one time the worked as it is supposed to do, I had the same setup).
  In the logs, there is not indication of any error, e.g. if I apply a filter, the log shows that the filter was applied - but then there is no indication about the "check all" or "uncheck all" even if I clicked on them - though notice it is not like turbo loader is completely ignoring the mouse, because when I am in that situation, if I click to clear the filter, exit turbo loader etc., eveyrthing works fine.
 Thanks in advance for any suggestion
  • Moved to Technical Help as it is about an add-on, not Daz Studio itself.
  • crosswindcrosswind Posts: 10,361
    Turbo loader has no function of "right-click menu" for checking/unchecking items.
    However, it always works on my side when filtering first, then Check Alll / Uncheck All ~
    Which Turbo Loader are you using ...? for which Genesis generation ?
    I had got the right click indication from the author of Turbo Loader, and I remember I did use it once in the past, but it was with a different version of Daz and on Windows 10, not 11, but in a way it not the most important, anything useful would be OK:
    The turbo loader is the one for G8F (though I have also the ones for generations, and the utilities, installed), the package is the one from 27/03/2022, the "check all" "uncheck all" works only on the full lits, though the doubt I start to have is if it may be linked also to the quantity of assets/morphs I have installed and the 64/32 bits difference (though I am on the 64 bit of Daz and Windows) - though in theory a 32 bits value can be hugely greater than the number of morphs I have (effectively, I would dare to say even bigger than the total number of morphs for Daz Studio products created till now).
    Again, I've never seen a right-click function in any Turbo Loader versions with Win10 or Win11 no matter 32/64 bits.... You can double confirm with the vendor in the commercial thread : https://www.daz3d.com/forums/discussion/557186/released-turbo-loader-for-genesis-8-and-8-1-commercial/p17
    The latest version of G8F turbo loader is 1.6 ~ check if you have the up-to-date one.
