Dragon throne
I have this product. http://www.daz3d.com/throne-of-the-dragon. ; I really like it and I want to transfer it to daz3d studio. Unfortunatelly bryce is software that crashes all the time when I am trying to do so. I can't even stransfer single thorne into studio.  Such technique as export object is not a good solution as it doesn't do good job in tranfering all maps properly. Any ideas how it can be transfered into Daz3d studio?  someone?
Mod edit to remove profanity
Post edited by Chohole on
    Are you converting the product into an OBJ when exporting it from Bryce and then importing the OBJ into DS?
    This older product only comes in Bryce native format.
  • Richard HaseltineRichard Haseltine Posts: 112,224
    As far as I know OBJ export is the only option - if the item uses procedural materials in Bryce then you will need to substitute some other texture or shader as those are applciation specific.
    I tried both of them. None of them do good job in exporting all maps properly. They do export the object. But this exported object has diffrent maps than original one like on the picture in Bryce.
    As Richard said   Bryce OBP tend to be set up for Bryce procedural materials, which will not export.  The store page does say that it has 9 Bryce material presets. You would have to substitute for these if you use it in any other program.
