Interactive Update
This used to be in Parameters.  Where can I find it in the 4.24?
  • crosswindcrosswind Posts: 10,351
    In the same way... but you need to make sure you've added Smoothing Modifier to the target figure/object beforehand ~~
    Its no longer listed in the parameters tab.
    It's still there ~~ check the ss down below.
    2560 x 1392 - 353K
  • jmucchiellojmucchiello Posts: 2,550
    What does it do? I've seen the setting and have no idea.
    Thank you.  It was not in the same place as the video I was watching .  Appreciate the help!
    If you turn it off it helps it not be so choppy when you are trying to pose and just allows things to be more smooth and fast in the viewport while working on a scene.
    I have never seen any difference with it turned on or off. And I have tried it with that on and with it off. It's always choppy. My 128GB, i9/14000, and RTX4090 isn't good enough, for some reason.
