3dlab item.
I just picked up the Throne pack from 3dLab. Installed through IM and the throne props are not there. Materials are, but no props. I've redownloaded and reinstalled several times to no avail. Anyone else have this issue?
  • felisfelis Posts: 6,493
    Link to product: https://www.daz3d.com/throne-pack
    I don't have it, but can't see others reporting it.
    Where are you looking? Have you tried finding the product and see what it includes?
  • crosswindcrosswind Posts: 10,237
    I don't have such issue on my side. Check Show Installed Files in DIM to see if the Props were installed properly.
    501 x 1294 - 126K
    1174 x 849 - 170K
    It looks like the pacakge installed properly. But the props are not where they should be.
    1234 x 1376 - 2M
    2884 x 872 - 395K
    1042 x 970 - 519K
    1042 x 970 - 824K
    edited September 2025
    You're with a Mac ?
    There should be a sub-folder named: .Thrones  DS version for Mac doesn't accpet a dot character in a folder name ? I don't know... I know almost nothing about Mac Os.
    501 x 1294 - 119K
    Post edited by crosswind on
  • crosswind said:
    You're with a Mac ?
    Yes, on a Mac mini. That maybe an issue with the dot character. Not sure. I'll keep messing around with it.
  • Tatefa3D said:
    crosswind said:
    You're with a Mac ?
    That fixed it! I found the file witht the dot and simply renamed it. The props are there now! Thank you for the help!!
    Great ! No problem !
  • Please report this to Tech Support
    I did. Thanks!
    I did. Thanks!
    Thank you
  • ElorElor Posts: 4,081
    It's used for hidden folders and files, so it's supported by MacOS.
    Finder will refuse to create a folder if it's name is starting with a dot though: if someone needs one, they will have to create it through the command line.
    If Daz has guidelines for PAs, ideally, they should be updated to prevent PAs from using a dot at the start of a folder's name (the exclamation point is valid on the other hand if a PA needs to place a folder or a file at the top of the list).
    Ah, it's good to know ! and a good suggestion for sure.
