Object library error question
Hi, I was loading some of my previously saved objects in library, and one of them give me error that says something like "one of objects missing, will load without missing object". I click "OK" and from a quick glance nothing is missing. Should I be worried? Have you encountered such with your saved objects?
Thanks in advance.
  • mermaid010mermaid010 Posts: 6,319
    I only had similar problems when trying to import freebies, not saved objects.
  • HoroHoro Posts: 11,776
    It can happen if the object was initially saved in an earlier version of Bryce and then saved it a newer one. This usually works but when you load that "transferred" object, you may get such an error. Check the object whether you find anything missing. If it looks OK, save it into a new library (create a new library for testing) and then load it again from there and check whether that error appears again. Such can happen with anything from any library - materials, textures, ...
