Problems running Daz Studio
This discussion was created from comments split from: VIrus attached to a file from DAZ?.
  • rusmus14rusmus14 Posts: 2
    So its not a virus? Then why is that when I run Daz and Iray I have weird things happen. Sometimes it will close for no reason. If someone has answers that would be great. I have invested a lot of money and do not want to see it go to waste.
    Russ
    Russ
    Exact errors, crash reports, log entries, full machine specs and detailed descriptions of  the problem(s)...
    But most of the time, sudden, unexpected crashes, with no 'it crashed' pop up usually indicate hardware or driver problems.  And on the hardware side the two most common causes are heat and bad RAM, with inadequate power being a not too distant third.  On the driver side...video drivers are the most common, but audio and network drivers can be a cause, too.
  • Richard HaseltineRichard Haseltine Posts: 112,229
    More details of the issues would help, it could be a memory issue, it could be heat if it happens while rendering, it could be a driver issue. Please post details of your system as well as details of the problems.
    I will split this to a new thread since it isn't directly related to the original thread.
