Content Library Issue
morrisonmpmorrisonmp Posts: 164
So, ever since I started using the DAZ Install Manager, I've had this issue where newly purchased/downloaded items didn't show up in my library after I installed them with DIM. The only way to fix this that I found was to run Content Database Management with Process Metadata Queue and Re-Import Metadata checked. I'm sure that isn't a good thing but it was a workaround that did the job even if the 10 minute wait each time was frustrating.
As of today, when I select those options it no longer seems to do anything and my newly installed content is not present in my Smart Content (and some of it appears in Content Library but seems to be missing parts).
I have not altered my libraries in any way. They are the standard out of the box settings. So what is happening? Why is my DIM installed content not showing up and why is the Content DB Maintenance no longer functional?
Any help is appreciated. Thanks.
Post edited by morrisonmp on
  • Smart Content indicates a database issue (if  reimport metadata fixed it then communication between DIM and the database - were you closing DS and starting DIM immediately to instal content?) If the files are missing in the Content Library too that usually indicates an issue with paths or the installation process - when you save some parts are missing, what do you mean? Do you get missing file messages for the user-facing files (textures and files from the data folder) or are you not seeing user-facing files (entries under Daz Studio Formats) that you know should have been placed?
