Error Opening File
Hello everyone. How is your day going so far?
Mine? Not so good.
So, I spent 6+ hours working with a client on a commission yesterday.
I open the file and get an error.
I look into my log file and find this sequence of statements.
2025-07-30 09:12:45.307 [INFO] :: Prepare asset load (open): /Scenes/Wrestle Brawl Babes/Commissions/Tori's Comms/Chun-Li vs Poison and Ivy/Scene 03 Render/Scene 03 Ivy.duf
2025-07-30 09:12:45.308 [INFO] :: Locking viewport redraw...
2025-07-30 09:12:45.308 [INFO] :: Viewport redraw locked.
2025-07-30 09:12:45.392 [VERBOSE] :: Native format content directories: 4
2025-07-30 09:12:45.392 [VERBOSE] :: Poser format content directories: 6
2025-07-30 09:12:45.392 [VERBOSE] :: Other import format content directories: 0
2025-07-30 09:12:45.392 [INFO] :: Begin asset load (open): /Scenes/Wrestle Brawl Babes/Commissions/Tori's Comms/Chun-Li vs Poison and Ivy/Scene 03 Render/Scene 03 Ivy.duf
2025-07-30 09:12:46.441 [INFO] :: Json Parser (1685915,30): Syntax Error - expected ',' or '}'
2025-07-30 09:12:46.475 [WARNING] :: Error loading asset: D:/Applications/Data/DAZ 3D/My DAZ 3D Library/Scenes/Wrestle Brawl Babes/Commissions/Tori's Comms/Chun-Li vs Poison and Ivy/Scene 03 Render/Scene 03 Ivy.duf
Operation failed
2025-07-30 09:12:47.275 [INFO] :: Unlocking viewport redraw...
2025-07-30 09:12:47.275 [INFO] :: Viewport redraw unlocked.
Is it possible to save my file? I JUST made it yesterdaaaay~ X.x;
  • Richard HaseltineRichard Haseltine Posts: 111,984
    That looks like a compression issue, possibly due to a file system glitch. You may be able to recover it with some kind or archive repair tool (by default scenes are compressed, usinf GZ format I believe) but nothing is certain. I would suggest making sure the compression option is off when saving scenes.
  • IceCrMnIceCrMn Posts: 2,334
    7zip can decompress daz studio files
    go here and selct the version you need Download
    Most likely the 64 bit Windows version https://www.7-zip.org/a/7z2500-x64.exe
    Hey man, I really appreciate you going out of your way but I think this file is cooked.
    When I extract it, it says "unexpected end of data." and when I open it, same problem.Expects a comma or ] but doesn't find one. I tried your method on other files, though. So, I can pocket this as a method in the future.
    Suuucks that this had to happen though.
  • Btw, I opened the file with Notepad++
    `Json Parser (1685915,30): Syntax Error - expected ',' or '}'`
    Was a line that stuck out.
    I went to that line and I did not see a ',' or a "}" out of place.
  • RuudLRuudL Posts: 227
    While in Notepad++ goto menu Language>J>Jason  On the leftside, where the linenumbers are, you'll see fold and unfold symbols ('-' and '+') You can check the validity of each segment by closing and opening it using those symbols.
    The last line of the file must be a line with only a closing bracket.
    Yes, but what is needed is a tool to repair them (if possible).
    Depending on where the file breakage lies there may be any number of close brackets/curly brackets missing - and just adding them wouldn't fix the issue, and might well not even alow the file to be opened.
    yea, 7zip I don't think can repair them just decompress them. I really don't know as all I've ever used it for was comperssing or decompressing files. I've litteraly never had the 7zip file manager open in all the years I've used it.
    I never compress my Studio files anymore. Iearned the hard way many years ago that it leads to lots of issues so stopped doing it and just bought ever larger storage. The 4TB Westerndigital "My Book" is great for this hobby.
    If the OP is on Windows, there is a file backup buitin to it that can make iterative backups of folders. Maybe that can be an option for backups?
    I don't use it myself, but I hear good things about it.
    There was no closing bracket at the end, so I put one in. Oddly enough I got the same error, same line.
    This is line 1685915 and 2 subsequent lines after:
    "label" : "Metallic "current_value" : 0,
    "enum_values" : [ "PBR Metallicity/Roughness", "PBR Specular/Glossiness", "Weighted" ]
    Everything honestly looks fine. I don't see where a comma is needed unless there needs to be a comma between Metalic and current value.
  • crosswindcrosswind Posts: 10,356
    edited July 2025
    From the coding you posted above,  at least there needs to be a comma in between "Metallic" and current_value, i.e.
    "label" : "Metallic ",
    Edit: yeah, and that " I missed !
    Though these codes still looks weird to me (Metallic should be Base Mixing) ...,  you can give it a try firstly. But be noted, in my experience of fixing corrupted file, you might further see next syntax error then.... Just see what will happen.
    Post edited by crosswind on
    "label" : "Metallic",
    All strings (labels and textvalues) must be quoted with double quotes. Numerals unquoted.
  • Hi Crosswind, I had chatGPT write a script to replace the "Metallic" with "Metallic", but at the end of the file I ran into this :
    "channel" : {
    "id" : "Metallic Weight",
    "type" : "float",
    "label" : "Metallic""c "c "c "c "c "c "c "c "c "c "c "c "c "c "c "c "c "c "c "c "c "c "c "c "c "c "c "c "c "c "c "c "c "c "c "c "c "c "c "c "c "c "c "c "c "c "c "c "c "c "c "c "c "c "c "c "c "c "c "c "c "c "c "c "c "c "c "c "c "c "c "c "c "c "c "c "c "c "c "c "c "c "c "c "c "c "
    I thought it was trying to write "current file" so I replaced it with :
    "channel" : {
    "type" : "float",
    "label" : "Metallic","current_value": 0
    Syntax was accepted by JSON editor online , opened it and... Nothing. Daz log won't even give me a reason anymore, just "Operation failed"
    Tried reloading Daz and opening, nothing.
    Even had chatGPT give it a look.
    My interpretation is that there were other surface texture data settings that didn't make it in and the malformed string at the end was a sign of that.
  • Thank you both for your help, but I'm just gonna remake the render.
    This file is cooked. xD
    edited July 2025
    Yup, that is like what I mentioned, the file might be further corrupted... The codes above seems incompleted. Is it possible that you attach the DUF file down below ? so that we may help to check ~~
