Instances to objects script
I recently purchased the instances to objects script from code66. For some reason I keep getting an error message while trying to run it with certain props.  I can see
the instances in the scene tab.  I don't know of another workaround or if there's a similar script that might work.
  • felisfelis Posts: 6,490
    You are rather sparse with information.
    What are you trying to make as objects?
    What error message do you get?
  • Richard HaseltineRichard Haseltine Posts: 111,254
    What version of Daz Studio?
  • I've using the latest version of daz.  There are instances that won't convert to objects when using the script from code66.
    This is the error log that I keep getting.      'TypeError: Result of expression 'oObj' [null] is not an object.'
    There are at least 5 instances that won't convert when I try and use the Instaedit script either.
    txt
    txt
    log.txt
    605B
  • crosswindcrosswind Posts: 10,227
    edited July 2025
    I'm not 100% sure but more likely they're not Instance nodes but Null or Group nodes. For instance, if you check them in Scene pane, you might be able to see the icon before an Instance node has dark gray color while the icon of a Null node has white color.
    Icon of a Group node is different which is easy to identify.
    A Null or Group node cannot be converted to an object, i.e. a Prop.
    You may post a screenshot of Scene pane if the issue still persists. Expand All before capturing the screenshot.
    559 x 1294 - 64K
    Post edited by crosswind on
