Animate Enabling Limits
marklgoldenbergmarklgoldenberg Posts: 4
edited June 2025 in Daz Studio Discussion
Trying to learn to animation. Wanted to start small and just do a walking animation. When I try to pull the length tab, I get Trim/Length End (disabled), as seen below in attached.
Any ideas how to enable it. I thought it was the animation program, so I download more animation walking and got same message.
715 x 217 - 29K
Post edited by marklgoldenberg on
  • ImagoImago Posts: 5,801
    edited June 2025
    You can add more blocks on the line or bake them into keyframes and then copy-paste them in the regular timeline to make it longer, after this, if you still want to use AniMate, you can bake them into an AniBloc.
    I see you are using the Lite version, to bake the keyframes you need to buy the full version.
    Also try adding more frames to your animation, I see it has just 30 frames, perhaps it will allow you lenghten the AniBloc with longer timeline. I don't use AniMate for my animation, so I'm not fully sure.
    Post edited by Imago on
