Installing Morph packages
Hi there,
I bought a few Morph packages and was wodnering if they will be installed automatically DAZ Install Manager, or should I do something else after that?
I noticed that there is a dashed circle with a down arrow on some of them.  When I right clicked on it it shows "Install".  Does it mean that these Morph packages have not been installed yet and I need to manually install them by clicking on that circle/arrow icon?
Thank you for your help,
_KN
  • Richard HaseltineRichard Haseltine Posts: 112,335
    That means the products are available through Daz Connect - but installing them through DIM is fine. They should work automatically if they are for Genesis or later; morphs for the older figures do need to be isntalled to the same content directory as the base figure in general, but other than that should just work.
  • edited February 2017
    Sorry if I shouldn't bump a thread but I have kind of the same question:
     I have the "Manly Men" morphs for Genesis but am confused on where to install them. Would they count as older morphs?  I found two different "morph" folders, one under "base" in genesis and another folder in the libraries under Runtime.. Or would they have to go somewhere else entirely?
    Post edited by kelly_leigh_crutcher on
    How are they packaged? usually you would isntall the files and folders from the zip - or from the Content or My Library folder in the zip - to the content directory, the folder that holds the Runtime and Data folders. If you mean http://www.daz3d.com/manly-men-m5 then using Install Manager or Connect would be the safest option if you don't understand the structure of content directories.
