Instant Rain did not work anymore (solved)
daybirddaybird Posts: 681
Got some problems with the instant rain setting from Dreamlight in the newest Daz version.
Could not load the prop and get a failure message.
Did that happen to anyone else?
Tried to reinstall it anew, but it did not work anyway.
Post edited by daybird on
  • felisfelis Posts: 6,632
    Link to product: https://www.daz3d.com/instant-rain
    I don't have it.
    Acccording to promos it is made of textures planes, so can't really imagine why it shouldn't work.
    What is the failure message you are getting (full text from the log)?
  • daybirddaybird Posts: 681
    2025-05-30 14:28:47.193 [WARNING] :: \src\sdksource\cloud\dzcloudtasknotifier.cpp(203): Invalid file header for encrypted file: "G:/Renderordner/DAZ content database/Applications/Data/DAZ 3D/My DAZ 3D Library/data/cloud/1_80174/props/dreamlight/iray/instant rain/instant rain load prop.duf.enc"
    2025-05-30 14:28:47.193 [ERROR] :: Open Stream Error - No stream for CloudFile: G:/Renderordner/DAZ content database/Applications/Data/DAZ 3D/My DAZ 3D Library/data/cloud/1_80174/props/dreamlight/iray/instant rain/instant rain load prop.duf.enc
    2025-05-30 14:28:47.193 [ERROR] :: Open File Failed - Could not read asset information: /props/dreamlight/iray/instant rain/instant rain load prop.duf
    2025-05-30 14:28:47.720 [INFO] :: Prepare asset load (merge): /Props/Dreamlight/Iray/Instant Rain/Instant Rain Load Prop.duf
    2025-05-30 14:28:47.720 [INFO] :: Locking viewport redraw...
    2025-05-30 14:28:47.720 [INFO] :: Viewport redraw locked.
    2025-05-30 14:28:47.820 [VERBOSE] :: Native format content directories: 6
    2025-05-30 14:28:47.820 [VERBOSE] :: Poser format content directories: 6
    2025-05-30 14:28:47.821 [VERBOSE] :: Other import format content directories: 1
    2025-05-30 14:28:47.821 [INFO] :: Begin asset load (merge): /Props/Dreamlight/Iray/Instant Rain/Instant Rain Load Prop.duf
    2025-05-30 14:28:47.821 [WARNING] :: \src\sdksource\cloud\dzcloudtasknotifier.cpp(203): Invalid file header for encrypted file: "G:/Renderordner/DAZ content database/Applications/Data/DAZ 3D/My DAZ 3D Library/data/cloud/1_80174/props/dreamlight/iray/instant rain/instant rain load prop.duf.enc"
    2025-05-30 14:28:47.821 [ERROR] :: Open Stream Error - No stream for CloudFile: G:/Renderordner/DAZ content database/Applications/Data/DAZ 3D/My DAZ 3D Library/data/cloud/1_80174/props/dreamlight/iray/instant rain/instant rain load prop.duf.enc
    2025-05-30 14:28:47.821 [ERROR] :: Open File Failed - Could not read file: /Props/Dreamlight/Iray/Instant Rain/Instant Rain Load Prop.duf
    2025-05-30 14:28:47.821 [WARNING] :: Error loading asset: G:/Renderordner/DAZ content database/Applications/Data/DAZ 3D/My DAZ 3D Library/data/cloud/1_80174/props/dreamlight/iray/instant rain/instant rain load prop.duf.enc
    Operation failed
    2025-05-30 14:28:47.893 [INFO] :: Unlocking viewport redraw...
    2025-05-30 14:28:47.893 [INFO] :: Viewport redraw unlocked.
  • LeanaLeana Posts: 13,645
    The error message points to a problem with a file installed via Connect (ie directly from DS). Is that how you usually install your content?
    No, normaly I only install over DIM
    Then that means a Connect version has been installed by mistake. You should uninstall it and then it will use your DIM version afterwards.
    Wohooo, Thank you so much Laena. It works again, you really, really saved my day. Big hug and kisses. :)
