Dforce is not simulating
Hi, I suddenly have a big problem with dforce. When I simulate an object (clothing) the simulation is going on but the object does not simulate any further. I use the same clothing in different scenes. when I start a new scene the clothing won´t simulate properly. (it contracts shortly and then it goes back into the unsimmulated shape even though the simulation is still running. I have added a dforce madifier ;) When I load an old scene however the clothing simmulates just fine. I can even load a new character into the scene and simulate the clothing on him without any problems, but when i start a new scene with the same clothing it does not. I have no idea how to fix this or even where to look. there is nothing in the logs that could indicate any issues.
Thanks for your help :)
  • Richard HaseltineRichard Haseltine Posts: 111,972
    Check the log file (Help_Troubleshooting>View Log File) for erros relating to the simulation towards the end of the log.
  • tiffyhhtiffyhh Posts: 6
    Thanks for the little hint. I could not figure out what was the problem though. I restarted my PC and now it works :)
    Sometimes, if dForce hits an issue, it will keep failing even with soemple things - usually an application restart is all that is needed, but I suppose with some driver/hardware combos a system restart might be needed to get the driver behaving.
  • Drogo NazhurDrogo Nazhur Posts: 1,354
    Having a similar problem but there are no errors in the log file. I just upgrafed to 4.24 -- everything was working fine in 4.23
