Daz Alpha 6.25 G3/G8 to G9 Pose Coverter issue
I use G3/G8 to G9 pose converter script by Zev0, in 4.23 and 4.24, it worked flawless, but in Alpha 6.25 built, it only allows me to convert one pose from g8 or G3 and than just fail to work altogether. Any fix for that? what alternative way I can use before there's an offical fix?
Scripts may well need work to run in Daz Studio 2025. It isn't always going to be the case, as it is with plug-ins, but there have been substantial changes in the Qt framework script engine (on which Daz Studio'd own script engine is built) and there may be changes the actual Daz Script methods to reflect structural changes. See several posts in https://www.daz3d.com/forums/discussion/727631/daz-studio-2025-6-25-2025-x-evergreen
k, that makes sense. But any alter way I can covert g8 pose to g9 without using scripts?
Do the pose conversion in DS 4.24 and save the converted pose or the whole scene, and continue to work or render in the Alpha if you want to.
Off the top of my head, @n_alexandru's scripts seem to be working with the alpha (I only tested it on a pose or two and it was after the alpha was first released):
https://www.daz3d.com/forums/discussion/605941/genesis-1-2-3-8-9-to-genesis-2-3-8-9-pose-converter-updated-2025-01-03
That will be too much work if I want to conver a whole batch of hundered poses, but thanks for the tip
edit: I just learnt on the forum that most scripts from 4.23 don't work in alpha 6.25, guess we will just wait for the next update.
