• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
    • Game Ready
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
  • Download Studio
  • Menu
  • Daz 3D
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
Notifications
Loading...
    • Categories
    • Recent Discussions
Daz 3D Forums > 3rd Party Software > Unity Discussion
Where is the scene?
kirascurrokirascurro Posts: 55
April 2025 in Unity Discussion
just exported this environment (https://www.daz3d.com/my-secret-garden) from Daz 4.23 to Unity 6 in Windows 11. the scene was highlighted in Daz during the bridge installation and the Bridge seemed to install ok. I have Daz in my Unity assets and in the top menu. But where is the actual .duf file? i know it won't be a .duf in Unity, but I thought i'd have a scene or something to click on. I found a URP folder under Assets/Daz3D/Support in Unity and imported that too, but no change. What am I missing? Did I need to create a new scene in Unity and add a plane or something to it? there is a sample scene in Unity that i planned on deleting when i got the Daz scene in, but it didn't import to the sample scene either.
  • ArtiniArtini Posts: 10,989
    April 2025 edited April 2025
    Have you saved your scene in Daz Studio before you exported it to Unity 6?
    To have properly exported scene from Daz Studio to Unity all items of the environment
    needs to be parented to some prop in Daz Studio.
    I usually choose something like ground, but the type of the prop does not matter much.
    The groups from Daz Studio does not export for me.
    I usually open Advanced Options in Daz to Unity bridge before sending it over to Unity.
    In Unity under Assets/Daz3D/Support  there is a file one need to run (double click on it) to finish the export.
    After the proper import to Unity the environment should show up in the current Unity scene,
    so I create some scene in Unity, before attempt to export from Daz Studio.
    Post edited by Artini on April 2025
    April 2025
    Please also look at the answer by ARealiti in the thread:
    https://www.daz3d.com/forums/discussion/718061/sending-a-set-to-unity#latest
  • kirascurrokirascurro Posts: 55
    April 2025
    thank you sooo much, Artini, for your reply. I had a feeling it might be something like sending individual props. I'm unable to work on my project this weekend, but I'll be back at it on Monday. you've given me an exact path to follow. i'll let you know how it goes. thanx, again!
    April 2025
    So things must have changed either with the new Daz or the new Unity (6). Even though i made everything but the original instance of the first prop i wanted to transfer over invisible, everything came over. they became prefabs in Unity. Right now I'm working thru placement and getting them textured with the Unity mesh (if that's the right way to put it). i really wish Daz would get involved and update us on these changes.
    April 2025
    i've found that, even after adding the material to a Daz mesh . everything is still white. i'm sure there's something else i need to do, but i'm an amateur in both Daz and Unity, so i'm not sure what. does anyone have any idea what might be going wrong? i've attached a pic of what it looks like.
    3820 x 1957 - 4M
    April 2025
    Yes, sometimes it happens.
    In such cases I am usually trying to open the prop from the main folder (in your case secret_garden)
    and not from the Prefabs folder.
    What render pipeline in Unity 6 do you use?
    April 2025
    I'm using URP, Artini. i also can't load from the Hierarchy. it gives me a red x. so I always load from the prefab folder. Can i change the render pipeline once the project is set up (if that's the problem) or do i need to start over? it's interesting that the terrain came in with color, but nothing else.
    May 2025 edited May 2025
    I have imported https://www.daz3d.com/my-secret-garden into Unity 6 URP
    using the FBX Export options in Daz Studio showed below.
    Then I have changed in Unity materials for Tree Leaves and Tree Trunks
    Specular Mask Cut Out to 1.
    The results are shown below.
    561 x 1009 - 136K
    1912 x 875 - 528K
    Post edited by Artini on May 2025
    May 2025
    hi, Artini. i must say after messing around with it a bit, that did help me a lot. there's no instructions about the FBX screen in the Daz to Unity instuctions and that's really important, the first time i transferred i only got materials, no shapes and nothing in the heirarchy. but then i tried again and everything came in. and guess what? all the props came in their exact positions! i'd much rather add materials to them, than have to place them. thank you so much. you went above and beyond transferring the scene yourself. i really appreciate that. i'll post it here when i have all the materials attached.
    May 2025
    You are very welcome.
    Please post your results, when you please.
    October 14 edited October 14
    hi, Artini. it's been quite awhile since you helped me, but i did want to show you what i did with the Daz asset. I could use very little, because of the polygon's in the asset. most of the foliage is Unity, and the pathway/cat had to be reduced in Blender. but thanx again for helping me get it into Unity at all. i love it!
    well, i can't seem to attach the pic from my computer. it says no file data can be found in your post. has there been changes here in the upload procedure?
    Post edited by kirascurro on October 14
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
