Adding New Controller Parameters
I created a controller parameter with ERC freeze. Can I add another parameter to that controller via ERC freeze and only selecting the individual parameter, or will it overwrite/messup the controller I already saved?
  • Richard HaseltineRichard Haseltine Posts: 111,921
    You first need to use ERC Bake, right-click in the Property Hierarchy pane, with the controller set to 1, to remove the existing links and turn them into local settings. Then set the new proerpty and edo the ERC Bake on the controller. Two successive ERC Freezes are one way to trigger duplicate formula issues.
  • mmoch25mmoch25 Posts: 145
    Thanks.
