Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
    • Game Ready
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
    • Creative Tools
    • AI Scene Enhancer
    • Generative Credits
    • Enterprise Tools
    • Synthetic Training Data
    • Physical AI
Download Studio
Notifications
Loading...
    • Categories
    • Recent Discussions
Hair does not look as expected
scuttlebunsscuttlebuns Posts: 39
March 2025 in Blender Discussion
I attached the render on both cycles and Eevee.I also attached blender material preview screenshot.
As you can see, on Eevee, the hair seems somewhat translucent and flat, and the texture is not rendering properly. I have ratracing enabled too, body renders almost identical on both cycles and eevee.
I'm using the Stable version 4.3.0 of Diffeomorphic DAZ Importer and Blender 4.3. Any advice? In material preview, it's at least loading the brown color, but in Eevee, it's cloudy and "flat."
The hair is not a dforce hair.
1920 x 1080 - 2M
1920 x 1080 - 2M
776 x 439 - 338K
  • PadonePadone Posts: 4,393
    March 2025
    This is expected. In general eevee has limitations over cycles so iray materials are approximated and may require some manual adjustments. Even more if we're talking about strand based hair, as the conversion is very simplified in this case.
  • scuttlebunsscuttlebuns Posts: 39
    March 2025 edited March 2025
    Do you have any idea what exactly to adjust? It doesn't seem to be a lighting issue, so what should I change? Eevee Next is now much closer cycles, right? It even has ray tracing. I tried changing color on the hair material and it's just changing the tint a bit and not making it less "flat."
    Post edited by scuttlebuns on March 2025
    March 2025
    It depends on the hair type and the options you choose for material conversion. For eevee it is better to use principled. The principled shader is documented on the blender docs, I'd go for tweaking the color and alpha, eventually transmission if it is used.
    https://docs.blender.org/manual/en/latest/render/shader_nodes/shader/principled.html
    March 2025
    Hmm, I'll have to figure out how to make this work with Principled BSDF.
    1199 x 313 - 55K
    Principled doesn't support translucency, but eevee should render the translucent bsdf fine enough, so if that's the setup you get you can keep it. If the hair is 100% translucent then your best option to tweak the translucency is to add a HSV node to the texture, making the hair darker will influence the translucency.
    700 x 218 - 34K
    Post edited by Padone on March 2025
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
