Install Manager
Are there a way to hide selected items(Ready to Download tab) in Install Manager? I have a bunch of Ps packages that I will not use.
/mipe
  • atticanneatticanne Posts: 3,009
    Tick in box, then right click and select hide.
  • fixmypcmikefixmypcmike Posts: 19,705
    You can also click the Download Filters button and uncheck software you don't use.
  • frank0314frank0314 Posts: 14,741
    You want to be careful cause some Ps files are needed for DS. The Ps will hold the geometry and setting. DS version of it will only have DS textures. Mainly on order packs though..
    Thanks for all reply's. What will define "order packs"? I'm not sure what that means. For a new guy like me is there a simple way to tell if I need the Ps package as well, or is the best way to keep them all installed to begin with?
    That was supposed to be "older packs".  The best way to know is to use the Download FIlters and uncheck Poser and other software you don't use, then the Ps files will only show up if they are needed in DS also.
  • Thanks again for your quick reply :) That will answer my questions.
