the program closes during rendering
in The Commons
Hello everyone.
Today I couldn't complete a rendering because the program crashes and closes at 70% of the rendering and gives me an error.
I hope someone can help me
txt
txt
cloudLog.txt
1024K
I also attach the screenshot
We would need the regular log, not the cloudlog - that is about Daz Studio working online to get metadata and install content etc.
Thanks for the reply.
Now I'm trying to do that rendering.
When the window opens after the rendering is blocked it saves me a zip with an errorlog.xml file, a crashdump.dmp file and a cloudLog.txt file inside
Rendering stopped abnormally again. I attach a screenshot. I restarted Daz and downloaded the log.txt file
I hope someone can help me solve this problem. Thanks
Hmm, the log just stops mid-render so nothing very helpful there. It might be worth using GPU-Z, from techPower Up, to monitor the GPU as your render - see if it is getting too hot, or memory is getting tight.
I finished a new rendering with some more elements to test and it didn't crash. Maybe there's something wrong with this composition...
Perhaps something about the data sent to iray is just weid enough to trigger an issue. If the scene reliably crashes you could make an error report via a support ticket, attaching the log, the crash report, and the scene file.
Ok, thanks, I'll see if I can do some cleaning and try again. If the problem persists I'll send a support ticket
