Genesis 9 geoshell
I'd like to use a geoshell to put a tattoo on my genesis 9 character, but am having trouble making the non-tattoo parts of the geoshell invisible so I can see the character's skin underneath. All the tutorials say to add a black/white opacity map under Cutout Opacity, but I don't see an option called Cutout Opacity on the geoshell surfaces. Is there somewhere else I do this?
That probably means it is using the PBRSkin shader, which doesn't have Cutout Opacity (because it breaks the sub-surface scattering). You can aply the Iray Uber base preset to the shell, then add your tattoo and opacity maps to that. In some cases you might be better off using a Decal anyway.
Thanks, that worked! Once I loaded in Iray Uber Base I was able to see cutout opacity and load in an opacity map (white for visible, black for invisible).
