• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
    • Game Ready
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
  • Download Studio
  • Menu
  • Daz 3D
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
Notifications
Loading...
    • Categories
    • Recent Discussions
Manual setting of materials for average DAZ transmapped hair
SnowSultanSnowSultan Posts: 3,845
February 2025 in Blender Discussion
Could someone suggest some manual material settings for typical transmapped (using opacity maps) DAZ hair? I've tried the following as a very basic setup and would just like to hear some recommendations on how to improve it, but I do not want to use Diffeomorphic or the DAZ Bridge; I want to set this up manually so I learn how different nodes affect the final look.
Using Principled BSDF with base color texture, hair's opacity map into Alpha, Bump or Normal maps into Normal (via Bump or Normal nodes, reduced strength). Node Wrangler likes to connect any Roughness maps into an Invert Color node before passing it along to the Roughness input. I have 32 set in the Render Properties for Min Transparent Bounces and Transparent Max Bounces. The hair looks OK, but has no highlights, and I'm not sure whether to use a Top Coat, Sheen, or what. I'm also not positive if the overall opacity settings are correct because they've been changed at least twice that I know of since Blender 3.6 or so, and I can't even find the Alpha settings that are supposedly in the Viewport Display for Cycles.
I am rendering with Cycles, using Blender 4.3. Thank you very much in advance for any help.
  • PadonePadone Posts: 4,367
    February 2025
    For the highlights on transmapped hair you have to use the anisotropic effect. You can also learn from the diffeomorphic setup, as each node is explained in the blender manual.
  • SnowSultanSnowSultan Posts: 3,845
    February 2025
    Doesn't Diffeomorphic create a custom shader that more closely matches the DAZ Uber shader though? I really want to use basic Blender shaders and the BSDF if possible.
    I thought maybe I had to use the anistropic method, but the hair I tried it on (curly hair) did not work very well. Thank you for confirming.
    February 2025
    Well yes, for transmapped hair it is a conversion from the uber shader so it could be complex depending on the daz material. Or you may want to convert to particles or hair curves, which can use the principled hair bsdf.
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
