a bug happen
This happen can't install daz stuido
zip
zip
InstallManager_error_report_250208-092613.zip
51K
  • What security software are you using?
  • wabroot
  • I don't know that one, but it may be worth disconnecting the mchine (assuming you have the install packages downloaded - if not do that, without installing, first), switch the security software off, and try reinstalling.
  • IceCrMnIceCrMn Posts: 2,334
    Says in you log
    IM00018869-02_PostgreSQLCMSWin64bit.zip.{9a68a808-65b1-e831-db4b-d8a786e056fc}.part
    the .part at the end of the file names means the file wasn't complettly downloaded when DIM tried to install it.
    You only got part of it..
    Probably should delete all those and try to download them again just to make sure you don't have corrupt or damaged downloads.
