Help Please
beachlegsbeachlegs Posts: 531
edited January 2025 in The Commons
I had all my Daz items everything on my external hard drive, I have just gone to my all items saved file and I got this message..F:/ All saved Poser stuff/ All poser items is not accesssible.The file or directory is currupt and unreadable. It has been great all day just turned my computer on and got that message...What has happened? and can I get it back? I have everything I own in that folder sad I feel like crying.
Post edited by beachlegs on
  • Is it still the F: drive? Sometimes, if you have more than one device coinnected, the letters can get shuffled.
  • Are you able to view the folder/drive at all (in Windows Explorer for example)?
  • beachlegsbeachlegs Posts: 531
    edited January 2025
    Yes it is the F: drive...Is there a way to fix it?
  • memcneil70memcneil70 Posts: 6,143
    When this has happened to me, I turn off the computer, pull out the plug for the external drive in question.
    Then power up the Windows computer, and open File Manager so you can see all drives.
    Then plug in the F: drive and watch in the corner for a message that an problem drive has been installed. If it doesn't show up and your F: drive appears like normal, see if the data is there.
    If that message does appear, follow instructions for it to repair your drive. In my experience it will not damage your data.
    But you may want to consider a new hard drive and transfer your data as soon as you can or backup your data.
    edited January 2025
    Nothing there.
    edited January 2025
    Thank you very much, I will try that now :)
  • beachlegs said:
    Nothing there.
    So you don't see the F: drive at all, or it is there but empty? Are you sure it is the same device as it was before, that the folder with your content isn't currently in WIndows with a different letter assigned?
    edited February 2025
    beachlegs said:
    Nothing there.
    Hello Richard this is what I have showing...Nothing in the folder above the warning.
  • AinmAinm Posts: 764
    Are the other folders on that drive working?
  • being able to open the drive itself is a good start
    I lost 4TB of stuff a year ago when a drive just stopped working
    the folder permission settings might have been changed so rightclick and check that
    if the folder is empty running Recuva or some other data recovery program might help
    if comfortable using CMD https://apps.microsoft.com/detail/9n26s50ln705?hl=en-gb&gl=US likely the safest free choice
    it's on my PC already
    Yes everything is fine,  just that one folder for some reason.
    Thank you my friend, I am trying out Stellar Data Recovery at the moment. See what happens it is a pain for sure frown
    Then the cause may just be a corrupt system file linked to that folder. If so, the files inside have a very good chance of being fine and recoverable. A recovery app like those Wendy linked could help with that.
    This one's a bit more complicated to do as you'll run the scan from the command prompt, but it's free and one of the steps recovery apps may try. If you're feeling adventurous:
    1. Window key + S
    2. Search for "cmd"
    3. Choose the Run as Administrator option in the search results
    4. Type "chkdsk f:" without quotations and hit enter. This can take a very long time
    5. You'll get a report on the drive. If you see something about the folder in question, entering "chkdsk f: /f" will then attempt to fix it (and any other errors too). If you get this far, restart your computer to see if it has worked.
    I'm sure there are more user friendly ways to do the same thing as above in Windows. Maybe someone else knows what those could be.
    beachlegs said:
    Nothing there.
    Hello Richard, This is the empty folder. I am running Stellar Data Recovery at the moment to see what happens.
    Thank you yes I tried doing this and it did not work , I am going to buy another harddrive, Thank you for your help :)
    1. Window key + S
    2. Search for "cmd"
    Thank you so much,  I am going to try this for sure anything is worth ago at this point. I appreciate your help my friend.
  • follow the steps in the link I gave, if you don't have the Windoes file recovery  install it first
    I have used it to recover stuff I accidentally deleted
    I am going to try it thank you :)
    1. Window key + S
    2. Search for "cmd"
    I want to thank everybody for your help,  A special thank you to ainm.sloinneadh I got everything back thanks to your advice.  I am so happy you would not believe THANK YOU. :)
    1. Window key + S
    2. Search for "cmd"
    You're very welcome, and I'm glad you got everything back smiley Good to see the helpful comments from the community too.
  • Glad it all worked out
    Thank you my friend :)
