Saving Lights
When you save an iray light as a PRESET, what is actually being saved?  Is it all the peramiters you've set for the light?  Or just some of them?
If you have a number of lights in your scene, all with different peramiters set, how do you save the lighting set-up as a PRESET?  As a light?  As a Scene Preset?  As something else?
Thanks!
  • TomhipTomhip Posts: 643
    You can save actual lights/cameras as a scene subset. Good grouping makes that easier.
  • What sort of lights? Yes, all the settings for the actual lights are saved - but not parenting to other items and not things like an Iray environment or emissive surfaces.
  • FauvistFauvist Posts: 2,291
    All kinds of lights.  The position of the sun on a particular time of day at a particular geographic location; spotlights that take a lot of time to set up in the scene - are their positions and all their settings saved?  Even when I save the whole scene, some of the settings change, like the size of the disk.  The sun also reverts back to what I suppose is its default position.  If I place a point light in each flame of a chandelier, you mean I can't parent the light to the flame?
    Some content I've purchased, I haven't used because it takes a long time to set it all up and I'm not sure it won't all disappear when I save and close the scene.
    Which is why I'm asking if I can save the different kinds of lights.  I'm not sure of what to save the light as - a wearable, a prop, a scene subset?
  • Sun/Sky is render Settinmgs, not lights as such - that would be the environments I mentioned were not included. Spotlights would save, yes, but the Pointlights should not be parented to the lanterns.
  • crosswindcrosswind Posts: 10,359
    Only 4 types of node-based Lights in a scene can be saved as Light Presets: Distance, Spot, Point and Linear Point. All of their Properties in Parameters pane are saved within a Light Preset.
    In your case, there's ambient light set in Environment Settings, node-based Lights, Props formed by surface-based Emissive Light + Point Lights, etc., better separately save them as Render Settings Preset, Light Preset and Scene Subset.
    Are you talking about iray?  I didn't know there were iray distant lights.
    No, I wasn't. These 4 types of lights are not Engine dependent... they work in 3DL, Iray and Filament ~
    Though in Iray a Linear point light is just a point light.
    That's right ~ Falloff effect only works with 3DL.
