Create primitive plane throws an error
Pitmatic
Hi
If I go to create a flat plane primitive I get an error message and I am not entering values in the dialog box just going with what is prepopulated what is wrong?
The primitive is created anyway but never had an error till now.
883 x 597 - 70K
Post edited by Pitmatic on
Is it perhaps because of the brackets in the name?
Maybe but daz studio is filling everything in iam rendering now wil try it later.
How are you launching the command? The error suggests that a script called HomePage is running it, and not passing the correct parameters.
made several primitive planes with the same values/entries and didn't get any error or other message. Also it doesn't really like an error message, but rather like some help text. Anything in the settings of giving any hints when using some DAZ functions?
I am using the menu create -> new primitive and clicking on OK as the plane is the default option
I tested the primitive plane on my MacMini M4 with the Public Build 4.23.1.8 installed. I noted each primitive has curved brackets in their Name and I was able to create three Planes to test a 'Plane (3)' in the Label: and had no issues. I matched all the other elements that @Pitmatic used.
I will note that I had just rebooted my computer due to loosing internet contact and after a large download from DIM and metadata work on the files.
Mary
So when did that "Usage: HomePage" dialogue pop up? After clicking Create > New Primitive, or after clicking Accept button in "Create New Primitive" dialogue?
