Thickener-like function
The Thickener product is fun but as usual, I want it to something it probably can't.
If I create a plane primative and apply a cutout opacity image, for example, the cutout is the silhouette of a person in white and the rest of the area is black. Is possible to turn that no longer square shaped plane into a 3D object? So I end up with a "thick" silhouette.
    You might me able to use that opacity mask as a displacement strength mask, but you would need a very dense mesh plane to get smooth edges.
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,805
    someone needs to make Cutouts (a Carrara plugin) for DAZ Studio enlightened
    it creates blimps from alpha png images and black and white masks
    if you have Zbrush there alternatively is the alpha to mesh procedure
    no idea if Blender has a function or plugin to do this
    Casual has a script for D|S that almost does it on flat subdivided planes
    https://sites.google.com/site/mcasualsdazscripts9/mcjimagebaseddelete
  • Seven193Seven193 Posts: 1,156
    You're trying to thicken a cutout?  For smooth edges, I would first vectorize the cutout using an image tracer. You can find free image trace tools that work online.  Then convert that vector into 3D. Then back to the Thickener tool.
  • jmucchiellojmucchiello Posts: 2,610
    I don't know what most of this means. Nor how to import a vectorized image from an image tracer. Nor how to convert a vector to 3D. If I can convert it to 3D why wouldn't I thicken it in that tool? Whatever that tool is.
    You said you're using plugin:
    https://www.daz3d.com/thickener-plug-in
    And it only works on 3D geometry. It doesn't thicken 2D image cutouts. So I gave a solution to convert your 2D cutout to 3D.
  • crosswindcrosswind Posts: 10,356
    PNG / Vector files can be easily converted to 3D mesh in Blender, it's a quick and totally free way. Search "blender image to mesh" on youtube, you may find lots of tutorials. You can get it done in a couple of minutes. Then thicken the mesh in Blender or import OBJ into DS, thicken it by using Thickener.
    yes, this is what the Carrara cutouts plugin and Zbrush Alpha to mesh does but being Blender it's free yes
    you want a cookie cutter not a whole sheet
  • V3DigitimesV3Digitimes Posts: 3,502
    If you want to do it in Daz Studio (just tested), you could work on a very subdivided (when you create your primitive) and paint the offset you want direcly on it using the "new push modifier weight node", go in "Node Weight Map Brush" of "Tools Settings Pane", then click on Add Map and paint on this map the positive or negative offset you want. (hold alt for negative). You cannot be very precise unless you are super subdivided because the facets are offset front or back.
    It does "thicken" them. It just doesn't follows the outline, instead it creates a clear 3D rectangular solid between the front and the back.
    Having never downloaded Blender. I doubt I could get it done in "a couple of minutes". But that's for the confidence in me. :)
     How "very" subdivided. I tried to create a plane with many subdivisions and Daz just crashed. So less than 10,000 I suppose?
