What's the Point of dForce on Tight Clothes?
Nyghtfall3DNyghtfall3D Posts: 817
edited January 2025 in The Commons
[What's the Point of dForce on Tight Clothes?] The title is the question.
  • HavosHavos Posts: 5,705
    If it is truly skin tight, so there is not even any slack in the sleeves, then when running with normal parameters you are unlikley to see much difference between the simulated and unsimulated version.
    However you could change some parameters so that the material expands during simulation, and that way you could turn a tight garment into a looser one.
  • Please put your question in the post body and the title - Daz 3D Forums
    It can help the cloth to bridge naturally, rather than sticking into every crevice and hollow on the body.
  • Matt_CastleMatt_Castle Posts: 3,300
    Some people seem to think that anything less than a skirt or a cape doesn't benefit from dForce, but it's the difference between this shirt sleeve levitating in mid air, and hanging naturally. (Note also that the lower edge of the sleeve has remained shorter even as the arm is raised, unlike the unsimulated version where the bottom edge has stretched to still allow the sleeve to sit square around the arm).
    And even in the extreme case of a close fitting top like this, in the dForced version (right), the straps actually sit tight rather than the morphs following over the contours of the figure or sitting loose in place (most notable where the strap is straighter around the collarbone and tighter under the breasts)
    Perhaps subtle to many, but there is a use to Dforcing clothing even if it's not a skirt or cape.
    1800 x 1200 - 692K
    1200 x 1200 - 503K
  • crosswindcrosswind Posts: 10,344
    There're a few properties can be utilized and tweaked on dynamic surfaces of a dForce tight garment to make various subtle change on the garment's geometry.
    1) like other said, tweaking Contraction-Expansion Ratio can help with making the garment looser or even more tighter, with proper setting of collision offset.
    2) with Stiffness / Buckling / Velocity smoothing properties plus various dForce modifier weight maps, subtle wrinkles / folds can be achieved on the garments.
    yada yada ~
    When using primitves or tools coming from some products, one can manage to do some semi-undress morphs when none are included with the clothes from the start. wink
  • 3DSaga3DSaga Posts: 944
    In the above example the bikini top with dForce looks like a much better fit, but sometimes a similar result can be obtained if the PA has included fitment that simulates body pressure. This is very effective for swimsuits, lingerie and other tight fitting clothing. I guess it comes down to the design of the individual clothing item, but I find dForce is far more effective for loose fitting clothing in general.
  • These answers make sense, and clarify things I didn't know about how clothing and character morphs interact.
    Thanks!
