Sharp Bends using Dforce hair
DougalDougal Posts: 13
edited December 2024 in New Users
Currently using dForce Hollie Long Hair for Genesis 9 | Daz 3D
It always seems to have these sharp bends, which really don't look good.  sad
I'm not sure how to smooth it out, tried upping the tessalation but that didn't seem to make a difference.
Any help would be appreciated!
1920 x 1080 - 3M
374 x 248 - 223K
445 x 252 - 274K
Post edited by Dougal on
  • crosswindcrosswind Posts: 10,351
    It's a sort of hair making issue...
    Go to Surfaces pane, select Hair surfaces, increase the value in property: PS Points (Per Hair)... so as to make them smoother. Be noted that setting bigger value will generate more faces/vertices on the hairs that may consume more system resources as well as VRAM, so better no more no less.
    2017 x 1291 - 3M
    2017 x 1293 - 3M
  • DougalDougal Posts: 13
    That did the trick!
    Thank you so much heart
