Man Friday's render queue
Mayamayadu01Mayamayadu01 Posts: 3
edited November 2024 in Daz Studio Discussion
Hello eveyrone,
I wanted to see if people also had trouble with the new MFQ3 and/or MFQ4 (the one integrated with Premier)
I often have issues where whenever I presss the option to only render scenes through visible cameras, the plugin renders through perspective view. Even worse, I start the queue, then go on about my day, and when I come back, it says it's working, opening files, rendering, spending many minutes on each, but it doesn't save the renders anywhere, despite the path being specified. I just don't understand.
It also has a box to checkthat says "ignore errors", but if a pop up message with an error shows up, the queue stops. I mean, why is it even here in the first place? Am I not understanding how to use the plugin properly?
I uploaded a screenshot. As you can see, before the highlighted scenes, it all went to the correct folder and rendered the camera view. I stopped the queue, worked a little, and when I started the queue again, the scenes with the same parameters didn't get saved at all, and worse, it was rendering the perspective view instead of the camera I had saved with the scene.
Before premier I had tried that plugin and quickly reversed to the original one since I thought it was so [bad].
But now, I'm stuck with MFQ4 and I'm losing my mind over all those wasted hours of fake rendering.
Looking forward to reading your comments and hopefully solutions to this.
(Edited by mod)
969 x 633 - 94K
Post edited by frank0314 on
