Camera tilt
I want the camera to rotate on itself perfectly like CTRL+RMB+drag is doing at the beginning, but the camera animation is mediocre. How to fix, if it's possible ?
https://youtu.be/DhkcQKZcolE
  • crosswindcrosswind Posts: 10,343
    edited November 2024
    You can add more keyframes in between the starting / ending frames (e.g. 10 frames per interval), i.e. insert a Keyframe then Bank the camera. Repeat this action from the starting frame to the ending frame.
    Post edited by crosswind on
  • Well, I did that first but the result is far from being as fluent as intended. At this point I should add keyframes on each of the 65 frames but it would be pretty impossible to reach an impeccable fluency.
    It is a very commonly-used technique that can make the banking / dolly etc. work smoothly with animated range, as long as you do it correctly....
    I used 15 frames interval as an example: https://mega.nz/file/uGhDGABa#EAzVR7ZGp93425ka2j3ddmYhSRu3Hltl02qOS5xkloU
  • Yes, it's doing the trick, although not perfect. Thank you.
