G9 imperfect poses
I ask for help to find a solution to the hip deformation with genesis 9, genesis 3 and 8 were perfect in the most complex movements
  • Please take the textures of the female figure, or use an untextured Drawstyle.
  • what do you mean by Drawstyle? the basic figure should be as correct as G3 and G8 are without changes or additionssurprise
  • LeanaLeana Posts: 13,565
    "Drawstyle" is the display mode for the viewport, ie Iray preview, texture shaded, and so on.
    Richard meant "take the texture off".
    It's not allowed to post a pic with a nude textured figure in the forums as there's no way to filter those pics out, so you need to either remove the texture, or set the viewport style to one that doesn't show the textures.
  • the problem remains
  • See Acceptable Ways of Handling Nudity  - blurring doesn't count.
    With Genesis 9 selected, if you go to the Parameters pane and look under Misc is Base Joint Correctives set to 100%? If not set it.
  • crosswindcrosswind Posts: 10,324
    Probably there're wrongly-dialed corrective morph(s) that brought your character distortion when posing. With Show Hidden Properties...turned On, in Parameters pane, select Currently Used, check if there's any corrective morph unexpectedly dialed.
  • thanks for your replies smileyand I read your rules on censorship I didn't imagine they were so strictsurprise
