Apply Glass Shaders in Daz 4.22
I've gotten the stained glass iray shaders ( https://www.daz3d.com/stained-glass--iray-shaders ). What item/product do i need to apply these shaders? What do i need to be able to use these shaders?
  • felisfelis Posts: 6,502
    You can apply a shader to any normal surface.
    Select the object in the scene tab, and the surface(s) you want to apply it to in the Surface tab, and apply the shader.
    You can try to create a primitive, e.g. a plane and apply it to that.
    Be aware for glass shaders, if it is applied only to a plane you must set thin walled in surface setting to On. If it is a solid object (has volume) it shall be set to Off.
