Saving a Geoshells
Hi I'm having a weird issue.   I have a geoshell set up on G9 Eye Figure parented to it.    I believe the correct workflow for saving a geosheel is to use Save Wearable Preset.
What I'm unclear on is how to save only the geoshell and which figure in the scene I set as the parent (the figure I select when choosing the Save Wearable Preset option).    I select G9 as the parent I can't save only the Geoshell, it takes the eyeballs as well.  If I choose the EyeBalls I get the whole G9 figure and the geoshell loses its shell node.
I think I've tried every combination of options but can't seem to crack it.
Help!
  • crosswindcrosswind Posts: 10,351
    edited October 2024
    The trick is: Unparent Genesis 9 Eyes before saving Wearable Preset for the geo-shell, then parent Genesis 9 Eyes back to G9 after saving the preset ~~
    Post edited by crosswind on
  • Thanks Crosswind, I take it the user then has to select the eyeball before applying the geometry shell?
    You need to select Genesis 9 Eyes node before saving Preset or applying Preset.
